Home > Think Tank > How to Fix Right-Click Not Working on Start Menu or Taskbar in Windows 11
Jun 6, 2024
Sometimes you will find in the use of the computer when the mouse right-click on the taskbar or start menu does not respond, click on the icon also does not respond, this is how it is? We encountered this situation should be how to solve it? You should know that the taskbar and start menu can be used to set up many things, if they can't be used, it will bring us a lot of trouble. In this article, we will introduce you to a few ways to solve this problem.
Method1: Restart File Explorer
Windows File Explorer is a program in Windows that runs a graphical interface. Whenever you have a Windows problem, such as a right-click on the taskbar that doesn't respond, restarting File Explorer can usually solve it.
  • Press Ctrl + Shift + Esc to open the Task Manager.
  • In the Processes tab of the Task Manager window, scroll down the list of running processes and find Windows Explorer.
  • Right-click Windows Explorer and select Restart.
Method2: Using System File Checker
When the system files of Windows get corrupted, many system components stop working. At this point we can use Windows' built-in tool SFC to find and fix various errors in the system.
  • Press Windows+R to open Run, type “cmd” in the text box, and then press Ctrl+Shift+Enter to open Command Prompt as an administrator.
open Command Prompt
  • Type the following command and press Enter:
sfc /scannow
Method 3: Using PowerShell
PowerShell is a cross-platform task automation solution consisting of a command-line shell, a scripting language, and a configuration management framework. The interface makes it easier for the users to change the system files and fix various errors.
  • Press Windows+R to open Run, type PowerShell in the text box, and then press Ctrl+Shift+Enter to open PowerShell as an administrator.
 open PowerShell
  • Enter the following command and press Enter:
Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)AppXManifest.xml"}
Method 4: Using Registry Editor
Editing the registry can resolve certain issues, but be cautious as it can cause system instability if done incorrectly. Always back up the registry before making changes.
  • Press Win + R to open the Run dialog. Type “regedit” and press Enter to open the Registry Editor.
  • Navigate to the following path:
HKEY_Local_Machine > Software > Microsoft > Windows > CurrentVersion > ImmersiveShell > Launcher
  • Right-click on Launcher, expand to New, and then click on DWORD (32-Bit) Value.
 New DWORD (32-Bit) Value
  • Name the new value as UseExperience. Double-click it and set the value to 0 and click OK.
 set the value to 0
The Start Menu and Taskbar improve usability and make navigation easier on Windows computers. However, some annoying errors cause this clicking on them to be unresponsive. When you encounter this problem, you can try the methods mentioned in this article. Hope this article helps you.
How to Stop Your PC from Waking Up Automatically in Windows 11How to Fix Taskbar Icons Not Showing on Windows 11How to Fix Photoshop Crashes on Windows
