Home > Think Tank > Is a Solid State Drive for You?
Jul 13, 2016
Is an SSD for you?
Check all that apply and get ready to bust out your credit card: You want nearly instant boot times: You can go from a cold boot to browsing the web in a matter of seconds with an SSD; the same window is often minutes with a traditional HDD.
You want extremely fast access for general applications and gaming: We’ve said it many times already but SSDs are blistering fast.
You want a quieter and less power hungry computer: As highlighted above, SSDs are silent and use significantly less power.
You’re able to use two drives; one for your OS and one for your media: Unless you’re storing just a handful of family pictures and a CD rip or two, you’ll need a more affordable traditional HDD to store your big files.
You’re willing to pay a significant premium for the benefits of rocking an SSD: This is the biggest one by far as the premium per GB is currently around 3000%.
While the performance increase is enormous 3000% more per GB is nothing to sneeze at. If your checklist looks more full than empty and you scoff at a mere 3000% premium in exchange for rocking the speediest disk around, congratulations an SSD is for you!
How to Enable or Disable Snap Assist in Windows 11How to Shut Down Your PC Without Waiting for an UpdateHow to Upgrade to Windows 11 26H2 Using a Single Command
