How to Monitor Your System by Using Wise Care 365 Pro
Apr 2, 2015
If you are really conscious about your system’s performance then it is necessary that you should monitor it regularly. Using Wise Care 365 Pro, you can keep an eye on system resource usages of your PC and find out what is limiting your system performance.
Home >  How To >  How to Monitor Your System by Using Wise Care 365 Pro
Wise Care 365 Pro can display all the essential information of your computer. It is a powerful system and hardware monitoring utility. FREE DOWNLOAD NOW!
We often wonder how to improve and monitor our PC’s performance. Now it is time to test Wise Care 365 Pro which can display all the essential information of your computer. On one hand, it can list all the running processes and you can shut down any of them which you don’t need. On the other hand, all the crucial hardware components will be shown briefly, that will make know much better about your computer.
What should you do to monitor your PC and keep it run smoothly?
Wise Care 365 Pro is a professional PC optimizing tool. With it you can keep an eye on the system resource usage of your computer. It’s free and very easy to use. Give it a try now!
Here, we will show you one of its functions which can help you to monitor your system. Just follow us.
Step 1: Launch Wise Care 365
Download and install Wise Care 365 Pro. And then launch it on the windows computer.
Step 2: Go to System Monitor
Click “System Monitor” button and you will find there are two parts in it: Process Monitor and Hardware Overview. Meanwhile, it will show the amount of the processes on the top.
Step 3: End a process
If you want to end any process, please click “End process” from here. Besides, you can also view the detail info and block net access. And there are two ways of displaying listed at the bottom.
Step 4: Take an overview of the hardware
From “Hardware Overview”, you can check the detailed information of your hardware easily, such as CPU, mainboard, memory, and so on.
Notes: You will find that there is a floating window in Wise Care 365 Pro. It can show the upload speed, download speed, memory usage and temperature clearly.
Conclusions
What’s more, Wise Care 365 Pro can do much more for your PC. It optimizes the PC’s performance, defrags disks and the windows registry, and manages the startup process as well as services.
Now Download Wise Care 365 Pro to experience the surprise it brings to you. If you have any questions, please contact us by leaving a message.
FacebookTwitter
